MacBook Pro to Panasonic 4K TV cable advice?
Graham_Brazendale
17
HI, I have a 2020 M1 Apple MacBook Pro connected to a Panasonic 4K TV via a USB C to 4k HDMI 2.0 cable, which works pretty well as a monitor.
With some images, it is slightly "blocky" and I wonder if it has anything to do with the quality of the HDMI cable?
would a better quality cable help at all?
Any advice would be much appreciated.
Best regards,
Graham.
Freddy
BANNED
May 18, 2022
862
185
570
Best regards,
Graham.
Unlikely to. If you do buy another cable though buy from Amazon where you can return it if it doesn’t make a difference like I suspect it won’t.
