After some deliberation regarding getting a DAC with analog input(s) in to the system with all connectivity conceivable either from PC via Firewire or USB or wirelessly via an Airport Express through Toslink optical (CD quality playback) and every considerable short (to) connection possible i've resigned to the fact the only option i have left is to get a Mac Mini and have it as part of the system. To be honest this wasn't the ideal solution as it adds another box to the now seven box system to make it eight. [:|] Originally the idea was to get rid of the CDP and add a DAC with Digital pre amp (more on this later) and use my now Mac which is over 20 cable meters away. With this kind of length i had been ruled out with USB connections as 5 meters would be the ideal maximum distance though putting a booster in at 5 meters you could get 10 (not sure how this would bode, but..) even then that was to short, this left either Firewire or the AE optical. After searching the www. and reading umpteen professional reviews and end user views regarding Firewire DAC's it really only boiled down to one brand which i would consider (a bit snobbish i know) in the end it didn't have the analog input's i needed and though i summed this up i one sentence it took a far bit of time to come to some conclusion. This left the Airport Express. I must say now that this is a viable option to wirelessly stream 44.1-16bit (CD quality) audio to the system but trying to hunt down a decent male optical Toslink connector (to) a male USB connector with no luck has made the AE a no go. So the Mac Mini comes in and it makes the whole thing much easier to do as it will will have all the connection right there with no fuss, though cost's more to do but i will look at pre-owned 5gb Mini rather than new. So back to the DAC and this is were the pre amp comes in, i will eventually sell the amp [] and speakers, double [] and go active [] and this may be sooner rather than later as current prices for the gear i have are good and if all goes well should make a profit [] So the Mac Mini it is and to the question (sorry i fancied a ramble): as it stands i have ripped 50 odd CD's on the Mac i have and before i carry on with it would i be able to transfer the iTunes library as it stands onto the Mini or would i have to start from scratch, in which case i will stop now. Also can i connect the Mini to the Mac so i can use the screen or would i need a separate monitor or maybe i can use the TV as a screen? Short and sweet in the end! []
