JohnHolmes:
Many thanks for the info Al!
I think it will be a while before I shall be buying a projector, so I will get back in touch with you then.
As I will be using a 50" Plasma at first, I don't think I want to be sitting any further than 12ft away from the screen. Is that gonna be too close to the S150s? When I get round to buying a projector I would then obviously move the seating further away.
Another question is do I need solid internal walls all around?
your very welcome John
seating distance will be fine, David is giving some good advice here as well I note.
My wall contruction is solid all the way round apart from where my room to the left goes into our games/gym room, we are in a purpose built underground basement John approx 14 x 6.5 mts.
the entry between the rooms is about 6.5 ft across so what I did here was to make some acoustically filled folding doors that fit between the opening, this stopped room reflection from the other side, dead.
My screen wall, side walls and ceiling are covered in Devore velvet to 1.6mts from the screen wall, this has created a total black hole where the screen is with zero light reflection, its transformed the image 100% and is without doubt the biggest improvement to the room regards image contrast Icould ever have made, Devore is simply fantastic. I would recomment this to anyone who has a dedicated room but please note it renders the room vitually no good for anything else unless you have good lighting, which fortunatley that was built into the room as we were contructing.
For the first reflection points I made acoustic panels floor to ceiling also covered with Devore as its acoustically transparent as well and these worked wonders for the audio qualities, also these are covering the surround side and rear MK`s as well John so really do make for a big improvement 2 ways.
My MX350 is firing into the solid wall approx 100mm from it and is now controlled by an Antimode 8033c, this once again, to my ears is now sounding as good I think as when I had the MX5100 in there so i`m really pleased with how it all sounds atm and I get some good comments from people who visit for a demo.
Having solid walls all round i think is a bonus but if contructing stud partition walls its very easy to acoustically insulate them and using sound block plaster boards help greatly as well. The one thing you don`t want to do is to make the room "Dead" as it will sound Dead to you, a little bit of reflection is needed in any room unless its going to be an anechoic chamber used for testing purposes.
Projector wise, The JVC`s at the mo are taken some beating and they have new things on the horizon which we can`t mention as yet so please don`t ask
. Epson are coming on strong with the TW 5500, its got great black level and can be ISF calibrated but once again new things on the horizon i`m sure, we can discuss that though nearer to the time as I know things will have changed for the better by the time you are ready.
please don`t hesitate John if you need any more help and if you ever want a chat or anything no problems, i`ll give you my no. or they can be found in my bio.
cheers Al
