Luxman DA06 connectivity (via USB digital in) question
siudai8888
22
Dear All,
I have a Luxman DA06 DAC, and would like to ask your help on a question.
According to the Luxman website (http://www.luxman.com/product/detail.php?id=11), the DA06 can take USB digital in for decoding.
May I ask if this USB digital in is limited to signal from a computer, or could it be from any device (e.g. streamer) that supports USB digital out?
I am considering buying a network streamer which has USB digital-out and connect to Luxman DA06 for decoding (Cocktail Audio X50(D)), see:-
https://www.cocktailaudio.com/home/sub01.php
Do you think the DA06 can work with the Cocktail Audio X50D (via USB digital-out) for decoding DSD files streamed from the X50D streamer?
Thank you for any help or advice you could provide!
