Loudspeakers for Cyrus Streamline 2
Ivek
18
6
18,525
I would like to buy speakers for Cyrus streamline 2. After several auditions I decided for the Dynaudio X14. I would like to ask You whether I could drive these loudspeakers with only 30 wpc Streamline. Or should I buy active Dynaudio X14a.
Regards Ivan
You can consider ANY active loudspeaker and just plug them into the digital output or pre-outs on the back of the speakers (depending what they have). This will allow you more output than the Cyrus is capable of. There’s a number of active speakers for you to consider at different price points.
If you want a passive speaker to work with the StreamLine’s 30wpc, the Heco Direkt Einklang are a good place to start - they’re £1850/pair. Their 94dB sensitivity will get more out of your Cyrus the most speakers out there, as most speakers are 90 or less.
