Have a marantz PM8005 and Mission LX-2 as you can se in my signature
It sounds good, not to bright as dali speakers often do and with a good bass (as much as the recordings allow it to be)
One thing i noticed is, when i play loud there isn't much agression in the sound and therefor it might not sound as loud as a pair of speaker that tend to change sound charateristic when playing loud, often to a agressive sound
I use -10 db attenuators and even when i don't use them i feel i can't play really loud, it does sound less agressive than all the other speaker i have had the last 10 years, it's clean and loud but just a little bit less than party level
Is the sensitivity just a bit lower from the mission's than most speakers or is it just because the sound is less agressive when i play loud, that i feel loud is not really loud or close to party level
