Welcome to the forum. You will get a bigger audience over on the hifi section. This part is more to tell us about what you use, rather than to seek advice.
The points you should add, include:-
1. your budget
2. Size of room
3 Musical preferences
4. Where you live if not UK, because prices and availability vary so much.
Generally, bearing in mind your decent turntable, I'd suggest you should budget up to around £500 to get the best results, if you can. The QA 3050 would be a super floor-standing speaker to hear. There are many alternatives that you'll find in the review section of the website (and magazine). If you need smaller, then allow for decent stands.
Good luck!
Hi, Not really a hi-fi matter but, I have a 'Book Shelf' mini Hi-Fi system which has an output socket for a sub-woofer. I don't want to leave this powered 'on' 24/7, so I want to find a self powered woofer which will switch off when no signal is present. Can anyone suggest a speaker that I could use, or a manufacturer of the amplifier unit?
Much obliged, Terry
