Looking for a 40'' 120 Hz TV in 4K
Blacksabbath25
309
88
10,970
Hi looking for a TV with a spec that will refresh at 120 Hz for my new Xbox series X when it comes and it needs to be 4K i do Like Sony a lot but looked and there TVs they only refresh at 100 Hz
so any ideas ?
Blacksabbath25
309
88
10,970
Just spoken to richer sounds and that TV you recommended doesn't do 120 refresh Rate but the TV that does cost £1499 which is a 48 '' and new for 2020 which i did not want to spend that kind of money just to play the Xbox on
Deleted member 2457
£100 in RS gift vouchers:
Deleted member 2457
U could see whether RS will price match and give u the £100 voucher too.
Blacksabbath25
309
88
10,970
At JL you could price match with these:
£950 roughly and you get 5 per cent voucher to price match too.
i manged to get a price match from richer sounds for this TV but again i was told this will not do 120 Hrz refresh rate only the LG will which is £1400
Deleted member 2457
Blacksabbath25
309
88
10,970
Oh yes it says that too in this review 4K at 60hz:
Cant believe that! Sorry mate.
Do not worry
Richer sounds said the LG OLED 49” 2020 model was the only TV that will do the 120 refresh rate for gaming but spending £1400 is to much just to play my Xbox on
Deleted member 2457
Yep, I see what you mean I just saw this list with HDMI 2.1 TVs but of course they don’t all do 120hz but the list is still small for just HDMI 2.1:
Deleted member 2457
Do not worry
Yep, in my view those LG OLED TVs should be under £1000! They cost more than the 55-inches.
Blacksabbath25
309
88
10,970
I agree the 55'' is cheaper but to big to put upstairs to play Xbox on it would have to be put downstairs but already have a Sony 4k TV downstairs .
I did look at YouTube at some of the TVs that will do the 120 Hz refresh rate and those Samsung's you posted are meant to be 120 Hz refresh rate so do not understand why the YouTubers are saying they are when the specs say 60 Hz - 100 Hz
Deleted member 2457
Hi mate, there is a cheaper LG 48-inch OLED called the BX which was on sale earlier in the year for £1200, it’s due to be released again soon. Currys were selling it:
You are going to have to check with HDMI 2.1 and 120hz though.
Deleted member 2457
I don’t understand it either mate.
Deleted member 2457
Deleted member 2457
The C 55-inch is now £1200!
Deleted member 2457
Here is the deal I would get if you have the space:
Price match at John Lewis online for £1000 with voucher code and get £100 vouchers making it £900!
Blacksabbath25
309
88
10,970
Its just to big for my needs as 40'' was my max size but find out that 43 '' there was more choice and buying a OLED is overkill price wise as i was hoping to buy something that was just normal 4k at the 120 refresh rate but nothing out there .
PC monitors are to small as i am sitting away from my TV so will have to run with my current TV for now until i can buy something that is under the £1000 mark
