Logitech Harmony One & Pure Evoke Flow
Check all your devices yourself on Harmony site here , also their forums are good for querires and support are good on fine tuning / tweaking where needed.
Hi went to my friends house and used his harmony one and it never worked my evoke flow ..........grrrrrrrrrrrrr
professorhat:
Why would it? Does the Evoke Flow come with a remote? Mine didn't...
You can buy a proper Pure one for it. Seem a bit lazy to me, but I'll probably succumb in the end.
I have the Evoke Flow and the proper pure remote, When you start you have to bind the remote to the radio
by selecting additional settings in the menu and selecting bind remote then you have to press repeat and shuffle
on the remote at the same time, Then press select on the remote. Do not know if this would apply to any other remote.
professorhat:
Ah - sounds like it's a wireless / bluetooth remote rather than infrared which will be why the Harmony One won't work...
is there anything i can buy to make it "infra-red"
