Logitech Harmony does not need the IR box for PS3?
Sorry to bump, but remote coming in the next couple days.
Has anyone used these non standard IR dongles?
Thanks again
Yes, you can use the Logic3 dongle, but:
1) It doesn't always work
2) You cannot power off the PS3 with it
3) 1 USB slot of the PS3 is permanently occupied.
I ditched it as soon as the Logitech PS3 adapter came which is a lot better.
But a lot more expensive. Just as long as I can pause and play and rewind, not to worried for a 5iver.
I would buy the Logitech sensor if it was 20.00 or less
