Listening to British rock - B&W CM7 or 684
Dear all,
I usually listen to British rock, from PF to Q to Kaiser Chiefs.
I've recently auditioned B&W 684 and found them terrific.The mids are excellent, the positioning is clear and vocals are perfect for me.
The amp was Arcam FMJ A18.
What I wanted to ask is:
1. Do I need to stick with this config or try the CM7, which can be bought used for pretty much the same price?
2. Will this amp be enough for CM7 or I should buy another from Arcam?
3. Maybe I should listen 684 and CM7 with Rega or Rotel?
abacus
1,336
1,154
21,070
Music is personal and subjective, compare a few combinations and see which suits your ears, then just go for it and stop worrying about what if.
Hope this helps
Bill
Shanka
123
I like the 684's , they are a great big fun speaker, I wouldn't say cm7's are better , certainly different, the only CM floorstanders I like are the 9's.
It really is down to you, I will say the 684's greatly benefit from as much power as you can give to them.
I would try with the other amps you suggested, the new Arcam 19, if you could find a s/hand A32 0r 38 maybe better still.
Listen as much as you can
Have fun
Thanks! Why did you find 684 more interesting? :quest: :quest: :quest:
richardw42
299
I suspect the CM7s need very careful amp matching.
I changed from a MF to Roksan. Went from hero to zero.
SpursGator
58
47
18,570
Generally speaking, British rock will sound better on the 684s and American rock sounds better on the CM7s.
Irish and Australian rock really require standmounts. Canadian rock is a completely different conversation and requires care. Note that listening to Bryan Adams and Rush on the same day during the break-in period can void your speakers' warranty for liability reasons.
Captain Duff
Wow, I didn't know that speakers had nationalist inclinations - do some speakers sound better with american music then? Or what about a German band playing British covers but who are actually based in France - would that require an extra sub in the set up or something?
