John Duncan said:jerry klinger said:John Duncan said:It's only overpriced if it isn't any good...
No ! - you should know this one. It's only overpriced if it doesn't sell. :roll:
Last time I heard a memorable Linn demo at a show it was the .... LP12/ Ekos SE setup.
Anyway John, can you sort out my Cambridge Streammagic 6 internet radio connection before I send it back to Richer? 😛ray:
Actually, I was wrong anyway - it's only overpriced if it's not made by one particular manufacturer. Is there a thread somewhere?
bigboss said:John Duncan said:I read 50k somewhere
Yup! :read:
bigboss said:Apparently, it's going to cost £50K in total. 😱
it'll be interesting to see the idea (which appears a good one) trickle down to affordable tech. Proprietary connections though, which is a mistake IMO.
Aren't AVI gang already claiming that the same tech is used in their speakers?
Alec said:bigboss said:John Duncan said:I read 50k somewhere
Yup! :read:
Not as far as I've seen.
relocated said:You are absolutely right Alec. No complaints from AVI other than the imaginary ones, I was surprised it took so long to bring AVI into it.
Perhaps a realisation that AVI and others saw the way the market was going long before others in the hifi business did. [Mags included of course]
manicm said:Maybe rather conveniently, but Linn seem to have a slightly definition of a source, also if you go to the Exakt forum the system seems to be a bit more complex than what's been said here, and indeed, the DAC is in the speaker itself and absolutely the last in the chain before output (but there's a lot of complexity which has me scratching my head if you read the forum further with more responses from the engineers), so this response from a Linn engineer:
Hi Macrotech,
"Source" is an overloaded term which may be what is causing the confusion.
If "source" is used as in Linn's philosophy of "source first", then the strap line makes a great deal of sense. In a source first design, the source is the first component that causes loss to the signal.
For an LP12, CD12, KDS, or KDSM, they were indeed the source as they were the first place loss was introduced.
In an Exakt system, the Exakt DSM losslessly sends the digital signal to the Exakt Speakers over Exakt Link. The Exakt Speakers are now the first place in the playback process where loss occurs and, as such, they are the source.
In a network sense, the KDS, KDSM, and Exakt DSM all remain "players", but the Exakt DSM is not a source in the source first sense.
Keith
What's confusing is that even though there's a DAC in the speaker that's just before output, it's not clear if there's ADC conversion for the supposedly analogue amplification.
Additional info:
The (mandatory) Exakt DSM has analogue inputs, and thus an ADC, but no DAC and thus no analogue outputs. And it retains network streaming functionality too - like a normal DS.
The digital crossover is called the Exakt Tunebox - and has presets for the Linn Klimax Exakt 350 speakers which incorporates the DACs and amplification.
Current analogue Klimax 350 speakers can be upgraded to Exakt.
Most interesting: the Tunebox will have an open interface and will be ultimately compatible and configurable with 3rd party or non-Linn speakers.
Linn are making claims, as are some guests who've heard the system, that a LP12 sounds better through Exakt! So in essence Exakt seems to be a very high-end hybrid digitising and streaming system compatible with analogue sources.
andyjm said:Manic, I am not sure what ADC is, but to clarify the system flow, the only amplification takes place in the speakers. Each driver (tweeter, woofer) has its own amp driven by its own D2A converter in turn driven by a DSP crossover. All of this is housed in the speaker enclosure itself.
The control box, ( whatever daft name it is) performs the function of a pre amp - source selection, volume control etc, but does this all digitally, so isn't a pre amp in the conventional sense. I believe the control box also acts as a streamer, and can have an A2D converter fitted to allow analogue sources to be digitised and played back through the system.
manicm said:As far as I can tell analogue amplification is used. Which really confused me, because although Linn says a pure digital stream reaches the DAC there must be ADC at the amplification stage.
steve_1979 said:
manicm said:Cno, as a Linn owner I'm sure some info has been passed through to you?
manicm said:Cno, can you get info 🙂
lindsayt said:If you have a vinyl source, such as an LP12 SE, my understanding is that the signal path is as follows:
Vinyl record, cartridge, phono amplification (eg Urika), ADC, digital signal processing including volume control, digital active corssover, separate DACs for each driver in the speaker, separate analogue power amps for each driver in the speaker, speaker drivers with port augmentation, room, ears, brain.
Hi Macrotech,
Keith
Additional info:
BenLaw said:manicm said:Maybe rather conveniently, but Linn seem to have a slightly definition of a source, also if you go to the Exakt forum the system seems to be a bit more complex than what's been said here, and indeed, the DAC is in the speaker itself and absolutely the last in the chain before output (but there's a lot of complexity which has me scratching my head if you read the forum further with more responses from the engineers), so this response from a Linn engineer:
Hi Macrotech,
Keith
Additional info:
Does anyone else think that definition of source is b*llocks?
