hey all!
i have just purchased a TV second hand however im looking to hook some 1200Watt speakers up to it, unfortunately the only outputs i have is:
1: digital optical port
2: headphone port.
i dont want a cinema system as i have nowhere for the DVD player.
how can i make this possible ?
is it as simple as plugging some active speakers into the headphone jack?
i can run a separate amp if that would be better but it needs to be a small unit.
i dont want to spend any ££££ until i know its going to work!
any help you guys can give would be great!!
cheers
2: headphone port.
cheers
