The OLED77Z3 adds 8K to LG’s new brightness-enhancing OLED technology to deliver a true flagship TV.
LG Z3 (OLED77Z3) : Read more
That's only QHD mate. The latest Apple M3 Pro has support for one 4K display as mentioned in the specs on the website.Look for the Alienware 27 360Hz QD-OLED Gaming Monitor - AW2725DF. Done.
I still prefer a 27-inch flatscreen, a 4K screen resolution is brilliant also the brightness can be adjusted in the OSD settings or instead, an ambient light sensor can mitigate the chances of low light screen brightness and be energy-efficient too. Cheers!Look for the Alienware 27 360Hz QD-OLED Gaming Monitor - AW2725DF. Monitors are kicking off right now. It's only 2560 X 1440.
Here's the thing about 4k though. The higher the resolution, the smaller they have to make the pixels. The smaller the pixels, the less light they can put out. At 27 inches, you really won't be able to tell the resolution at a normal viewing distance. It will be dimmer though and use more energy to give you 4k you really won't notice.
For PC monitors, if your going 42 inches, you'll get that discernable 4k and still have some HDR punch. Otherwise, choose better HDR and lower energy cost.
