LG LED Not Saving the Channels!
Aref
Hi
I have got a new LG LED but i have an issue: when i switch off and then on all the digital channels are wiped!
I have to rescan every time i witch on!
Any one can help me please? Thanks in advance!
When you go through the channel set up process have you followed all the steps?
Have you updated the firmware on the TV and tried the channel set up process again?
hi oldboy
yes i followed all the steps since after i rescan, all of them apear but when i switch off and then on; all the channels are gone again.
what firmware is?
Aref said:
hi oldboy
what firmware is?
Best to call LG tech support uk. If they take you through the steps & you still get the same problem at least they will exchange the set for you. It does seem like a software problem. Firmware update should fix it. Give them a call & they will talk you through the whole process.
Aref said:
hi oldboy
what firmware is?
Aref,
Firmware is the version of software installed on the TV. If you go into the menu of the TV and go to the settings section you should see an option named "about this TV" or similar, on my LG OLED it's right at the bottom but your menu may be different. In there you will see an option to update the firmware/software, the TV needs to be connected to the internet to do this or alternatively you can download it to a USB stick and do it via the USB connection on the TV.
If the TV persists with the issue once it's up to date then I would echo the other members advice and contact LG as it sounds to me like a software issue. As Son_of_SJ suggested it would be helpful if you could provide the model number of the TV if at all possible.
