LG 55eg910 vs LG 55ec930v TV OLED
Howdy campers,
Just ordered the LG OLED E model turning up next Tuesday! *yahoo*
bigboss said:
Try a factory reset gel. You will lose all calibration settings, but that may just solve the HDR issue.
thats just what Panasonic said, how did you know that?
I have sold it as calibrated though? So I can't reset it.
rocketrazor said:
gel said:
Howdy campers,
I'm assuming this is the £5000 tv that so far everyone is moaning about on avforums?
Nope, £3500 I got the 55-inch.
I suppose I could write down the calibrated settings and then do a factory re-set?
spiny norman said:
Odds-on it'll be cancelled by the end of the week.
Not this one.
You could do that, but make sure that you write down ALL the calibrated settings, or ask Nick or Gordon for them. If you do the reset, you can't just put in some or most of the calibrated settings, you'll have to re-input ALL the previously calibrated settings. But the reset might make you like the Panasonic OLED again, perhaps to the extent that you decide not to sell it, which seems to be a fraught and drawn-out process anyway.
Alternatively, you really should get another calibration done if the previous calibration doesn't suit you. That's much, much cheaper than getting a new television .... and I hope that you won't regret going back down to a 55-inch!
No, I didn't find the jump from 55-inches to 65-inches big anyway.
If your dead set on selling it Gel and you have sold it as calibrated, then personally I wouldn't touch any of the settings, and I wouldn't do a factory reset. If your thinking of keeping it and getting it calibrated again then a reset would be a good idea. At this point in time, as you have order the LG 55" E series i'd leave the Panasonic alone.
Yep, agreed. There were just too many settings in the end to write them all down.
Son_of_SJ said:
Yes, it could be a lot to write down. For instance, here are the calibration settings (copied and pasted from Mr Steve Withers's PDF file) for my LG 60PZ950T plasma, which has moved from the kitchen to the front bedroom since the calibraton:
Aspect Ratio! ! ! Just Scan! Just ScanPicture Mode! ! ! Expert 1 (2D)! Expert 1 (3D)Contrast! ! ! ! ! 75! ! ! 100Brightness!! ! ! ! 41! ! ! 50Colour! ! ! ! ! 50! ! ! 50Tint! ! ! ! ! ! 50! ! ! 50Dynamic Contrast! ! ! Off! ! ! OffNoise Reduction!! ! ! Off! ! ! OffSuper Resolution! ! ! Off! ! ! OffGamma! ! ! ! ! Medium! ! LowBlack Level! ! ! ! High! ! ! LowColour Gamut! ! ! ! Standard! ! StandardEdge Enhancer! ! ! ! Off! ! ! OffColour Filter! ! ! ! Off! ! ! OffColour Temperature! ! ! Warm! ! WarmTwo Point White BalanceRed Contrast! ! ! ! -10! ! ! -10Green Contrast! ! ! ! 17! ! ! 0Blue Contrast! ! ! ! 18! ! ! 22Red Brightness! ! ! ! 0! ! ! 0Green Brightness! ! ! 0! ! ! 0Blue Brightness! ! ! ! -3! ! ! 0Red Colour! ! ! ! -5! ! ! -15Red Tint! ! ! ! ! -15! ! ! 0Green Hue!! ! ! ! 0! ! ! 0Green Saturation! ! ! 0! ! ! 0Blue Hue! ! ! ! ! -15! ! ! -20Blue Saturation! ! ! ! -10! ! ! 0Cyan Hue! ! ! ! ! 0! ! ! 0Cyan Saturation!! ! ! -10! ! ! 0Magenta Hue! ! ! ! 0! ! ! -4Magenta Saturation! ! ! 3! ! ! 3Yellow Hue!! ! ! ! 0! ! ! -4Yellow Saturation! ! ! 5! ! ! 14
its longer than that, and there's two settings night and day.
But if you are set on selling the Panasonic, maybe best not to touch it now. But I just hope that you like the new 55" E6, and you should get it calibrated.
gel said:
Son_of_SJ said:
New X-certificate avatar, gel?
Yep!  *biggrin*
He transitioned from upside down batman to what looks like a late night viewing of babestation then now a googled image of something i dont wish to describe. Although i have seen that image before..whats gonna be the next?
