LG 50PK990 Video review.
I was impressed with the written review of this TV and now I have just seen it on the video review it looks even more appealing. To even be compared to a Kuro is quite an honour, especially when it gets the full 5 stars at £1600 and you can buy it for £1251.50 here
One problem though, I cannot seem to find a wall mount for this screen. Are there any designed specifically for this set please? If not do you know of any suitable ones? I would prefer a flush wall fixing if possible. If I could find a suitable one and get this for the advertised price I think I'd have bagged quite a bargain
The LG, I have seen this close up, astonishingly panache and minimalistic, the single sheet surface frame appearance is just marvellous. Just goes to show how far the LG have advanced.I was seduced by it and the review
I have seen the new Panas with the dimpled edge laminate frame finish and with the latest Picture processing. It looks very chic and prettier than the older Panas.
I certainly felt they both look sexier than the Sonys. I concede. But the LG and Pana do cost more.
Andrew Everard
1,878
IIRC LG makes its own ultra-slim wall-mount for its TVs. Admittedly I only saw it in pre-prod form when I was visiting the company back in December 09, but I am sure your local LG dealer, or LG's UK operation, would be able to advise.
Andrew Everard:IIRC LG makes its own ultra-slim wall-mount for its TVs. Admittedly I only saw it in pre-prod form when I was visiting the company back in December 09, but I am sure your local LG dealer, or LG's UK operation, would be able to advise.
Cheers for that, I emailed the seller in the above link, even they admitted to not being able to provide the wall mount!
Andrew Everard
1,878
I'd suggest a call direct to LG: I suspect the novel mounting system available from this site among others will do the job, as it fits all TVs with VESA (standard) mounting points up to 48kg, and sits the screen just 1.5cm off the wall, but it'd be best to check directly with LG first.
Thanks again Andrew that looks ideal and its cheap
It's a rather strange looking thing though!
