LG 22LG3000 or similar...
I am looking for a good 22" LCD monitor for my bedroom that is £300 or under, and I came across this new LG 22LG3000, which seems to fit the bill for me. However I can not find out when said LCD will be released, as there is not too much infomation on this. Can anyone help?
Also if anyone has a suggestion on a better LCD at a similar price and size then I would be glad to hear them. I would like to spend £300 or less, but an willing to stretch it to a maximum of £350.
Thanks.
Hello, that model is a brand new one - not sure that it's been released yet.
I found this LG one for £229 play.com, you can get a further 5% off if you enter "experience08" at the checkout screen and if you want an extra 4% off then register at quidco.com BEFOREHAND and then click the play.com link within quidco and you will earn 4% cashback on top of the 5% voucher!
http://www.play.com/Electronics/Electronics/4-/3348756/LG-22-M228WA-HD-Ready-Widescreen-LCD-TV-Monitor/Product.html?dpr=104607
Cheers,
JSM
Thanks JSM for your input. I had a look at this monitor and although the price is tempting, it does not have a HDMI interface, and reviews have noted its bad sound quality. I dont really want to also have to plug the TV into speakers aswell. I also looked at the other version of the above model on play.com which has HDMI, but the same sound issues. I like the look of the newer LG, which has 2 HDMI ports and a good contrast ratio, and hopefully better sound production. You can find the specs of the new one here...
http://uk.lge.com/products/model/detail/lcdtv_22lg3000.jhtml
It is annoying that LG have already began advertising the monitor without any mention of when it will be available for purchase, I found the monitor listed on some online retailers website for £299.99 but they do not state when the monitor will be able for delivery. The retailer simply states 'Pre-order Now. Waiting release from Manufacturer.'
Where can I find this infomation?
LG replied to my query and indeed stated that the monitor would be available sometime in June, which is abit misleading for a spring 2008 line up. I think I will go for one of the samsung 22 or 23 inch monitors instead of the older LG models. Now to find the best deal on these. Thanks
