stefanom said:
lewis hurlin said:
Thanks for the tips. I will send it of to fidelity as not confident with a soldering iron. I want the level 1 upgrade plus changing phono sockets as stock ones are crap , which ones should I go for? Also mains cable too
Hi I replaced mine RCA sockets with Neutrik NYS367. Gold-plated and fit easily to the chassis.
You should mod your player, you won't regret it. I am in the process of modding my 15 year old CD63 KI. I have already swapped diodes and some critical capacitors in various stages. My player has taken a leap forward in performance. Next on agenda is replacing op-amps for much better ones and adding low jitter clock.
Trust me you will be amazed by the BIG improvement in SQ when you have done all the mods
I suggest you change the stock transformer with a much bigger capacity and there will be noticeable improvement in performance. Then change the smoothing caps for the transformers and other critical caps for the servo and opamps. Change the diodes, disable the HDAM and headphone circuit, disable the stock muting circuit and replace it with relay operated muting circuit, change the opamps to 4562HA or diccrete opamps like Burson, change the low jitter clocks for the servo (8.xx Mhz), DAC and decoder (16.xx Mhz), use very low noise regulators supplying independent power to the ICs, decoder and DAC etc. Put damping pads on the CDP case.
