LCD screen cleaning
Have a Sony KDL40W4500 anyone recommend a good way of cleaning the screen of dust and not generate to much static in the process.
no problems at the moment with backlight bleeding and clouding on the w4500 great picture quality with both Sky plus and blu-ray very pleased with w4500 better quality than I expected.
Would recommend use of a damp microfibre cloth . Roll it into a sausage shape and rotate it constantly as you traverse the screen ; this way the (abrasive ) dust is removed and not presented again to the soft plastic surface . No static generated so long as cloth is damp.
I have one of those Pledge fluffy dusters, sucks up dust like a magnet. Excellent for the shiny tv surround and stand, also gets all the small dust particles from the microfibre cloth. I was using the cloth dry so it tended to move the dust around rather than remove it.
I highly recommend SafeClean Cleaning pad which is approved by the major manufacturers for cleaning LCDs and Plasmas:
http://www.cleansafe.co.uk/
The cleaning fluid is alcohol free and leaves an anti-static, optically pure and water repellent film. Its also safe to use on screens with any special coatings.
