Torres09 said:Hi chebby, how long did your update take to complete?
Mine is showing Authenticating for an hour now, I can't use the volume or change a source, what a pain |(
Womaz said:This post makes me pleased I am sticking with CDs for as long as I possibly can 🙂
ajaxson said:Update seemed to download fine but now my airplay (from iPhone 4S) doesn't work. AirPlay icon goes blue for a couple of seconds then stops. Any ideas?
It's best have the unit connected to your router with ethernet, then any pending updates will automatically alert you when you power on.myants said:Hi,
Is it possible to upgrade firmware manually (offline mode with USB)?
Any body know where to download the lastest firmware for M-CR603?
:help:
