- Aug 10, 2019
- 2,556
- 5
- 0
I had been struggling with getting my Sony BDP-S570 to stream music from my Western Digital NAS hard drive and then I realised what the problem was. I have all of my music in WMA Lossless format, which of course is not supported by the blu-ray player. The player only supports standard WMA files. So then I thought, not to worry, I'm looking to get an AV receiver at some point in the not too distant future and I will go for one that supports DLNA. If I spend a reasonable amount and get a decent one, it would surely support Lossless music. Well it would appear that I was wrong about that one too...
I've been looking at the Yamaha RX-V3067 as I need a fair bit of grunt to run my speakers. I was also looking at the Pioneer VSX-LX83 as the Pioneer gets rave reviews from What Hi-Fi. The Yamaha doesn't seem to specify what specific file formats it supports, other than to state WMA, WAV etc. the Pioneer specifies that it only supports up to 320 Kbps music files. I'm sure an email to Yamaha would clarify if that amp is the same as the Pioneer or if it does actually support Lossless files...
Is it standard for current tech to only support compressed music files over DLNA? It seems a bit backwards to compress the music, stream it, "enhance" the music through the AV amp's onboard DAC and then have it going out to your speakers. If I have the capacity in my 2TB NAS hard drive to store my music uncompressed, and I have a Gigabit home network capable of streaming the files, it seems only appropriate that I have an amp that is capable of dealing with the uncompressed music.
Am I asking too much of the tech? Or am I just looking at the wrong products? It's all very well having"HD audio" but if you can't stream your Lossless media files, what's the point???
