diversityfg said:
Clare Newsome said:
diversityfg said:
Clare Newsome said:
I think you're missing the point - this was cables apparently submitted by a professional installer for testing to these labs. Products that were commercially available on the market (ie HDMI specified) that behaved very differently and were built very differently.
I thought it would be of interest to the people suggesting that all cables - if carrying the HDMI logo - were essentially the same. This article would suggest not.
It also contests the assumption, made by some, that 'HDMI cables either work or they don't' - that can vary on the system they're being used in.
This would appear to suggest that one of them did not work.
However, the one that
failed used a very thin solid gauge wire size for the HDCP/EDID channel compared with the cable that worked. The HDCP/EDID wires within the cable that
failed are at least two times smaller in diameter than the one that worked
Read it again - the one that 'failed' only did so in a certain system; it worked fine in another:
"When tested with one TV, however, only one of the cables worked, but with another TV they both worked."
Fair enough. Still, a rare example i should imagine. I am still concerned that any cables reviewed that got less than top marks must have been wrongly endorsed, presuming What Hifis assessment of them was correct.
This casts doubt over those that endorse these cables as 100% capable.
I've personally encountered cables that work with one product but not another, too - but then i'm a projector user, and HDMI performance at longer lengths can be a tricky.
Re the endorsement issue, here's one manufacturer's take on it:
"Real world variation and tolerances may mean that a cable produced to simply ‘meet’ the specification on paper, may not actually comply every time in production. Similarly, both electronic display and source equipment will experience some variation in production and may also suffer some degradation of their performances over time. This means it’s not enough for a cable to merely meet the required specifications, it always needs to exceed them.
Unfortunately, these are not the only factors that contribute to poor performance. Poor choice of materials, imprecise control of cable geometries during manufacture, as well as physical imperfections and construction tolerances are all sources of error which can degrade performance, even after the original design has been passed as adequate."
That's from QED -
full text here.
