Question Knocking on things to define quality (?)
AJM1981
97
27
70
I was watching a review online last week by a guy from kind of popular channel. He was comparing normal bookshelves with some Klipsch speakers. His opinion was that the Klipsch were overpriced due to the *knock* *knock* more hollow cabinet whereas the other speaker was heavier and more massive.
Sometimes I have the idea this tradition of knocking on things has passed on from generations from the stone age till now (stone age people always won by the way)
Given that the klipsch uses a horn and a different design in general there should also be a different more open and less massive tone while knocking on it.
I don't believe that knocking on gear in general does something to define the quality at all these days. But I could be dead wrong.
nopiano
728
455
19,270
I guess that if you’re comparing similar sized and designed speakers it might tell you something. But I agree, comparing a ported box with domes to a horn-loaded something, might not be so useful.
I wonder if they knock on planars and electrostatics too!
12th Monkey
1,040
672
12,070
The audio equivalent of kicking tyres, I suppose. I have knocked the D7s, and the sound dies noticeably more quickly than on their predecessors - which I am guessing is good.
abacus
526
239
19,270
All box cabinets resonate, the knock just indicates which is the better damped, (The more expensive by and large the better the damping) however while higher damping is better its effect can be reduced by proper design. (Electrostatics etc. don’t have cabinets as such)
BTW: If you want to add damping to your speakers (To give a better knock performance) just get some sound damping pads and tick them to inside walls of the cabinet. (Just don’t be surprised if it sounds worse)
If it’s the site I think you mean, it used to be great, but now it is just a joke and best ignored.
Bill
AEJim
74
12
Something we all do to one degree or another I think, I often judge car build by the quality of the door handles as it's the first touch-point!
The only problem doing this with speakers is that different manufacturers have different techniques for creating their sound - some prefer thin and light build, using the cabinet resonances while others go heavy or use lots of bracing to minimise resonance. All things being equal it's an understandable simple gauge of quality, just not the full picture. :)
Reactions: DougK and Al ears
ASK THE COMMUNITY
