KEF has improved upon last year’s Award-winning all-in-one system with an innovative and entertaining sequel.
KEF LS50 Wireless II : Read more
Does anyone spending two grand on excellent Hi-Fi speakers really use Bluetooth much? It is a last resort in my book.Very troubling that KEF is reusing the same awful Bluetooth 4.2 chips from 2016. Shouldn't every self respecting hi-fi system at the very least support aptX HD? Where else did they cut corners?
With the new codecs available it didn't have to be that way though. Good Bluetooth support would also have been useful for desktop speaker use now that USB input is gone.Does anyone spending two grand on excellent Hi-Fi speakers really use Bluetooth much? It is a last resort in my book.
Agree completely. All bluetooth versions are simply bad, they go from horrible to dismal. I would guess, that bluetooth is included simply as a courtesy. The so called aptx HD. Has zero HD about it.Does anyone spending two grand on excellent Hi-Fi speakers really use Bluetooth much? It is a last resort in my book.
Im sorry to disagree, though more is not always necessarily better, full theoretical reproduction of the sound spectrum is 24/96. CD is 16/48. Yes, CD is more than enough for the majority of music, certainly not all. Furtheremore, many CD's are atrociously badly compressed and multiple generations away from the master recording. Unfortunately the format of a recording is no guarantee of fidelity.Wish you guys would get off the hi-res bandwagon, CD quality is all you need for perfect reproduction. The quality of the recording is everything, hi-res doesn't cure a bad recording. And yes I do have some hi-res files... waste of money.
No need to apologise, we're just having a chat. Do you believe that a hi-res file of the same recording will somehow cure this? I don't because you don't know which master has been used for the recording, as you say it could be generations away from the original... the original may not even exist now. Very difficult to know what you are actually purchasing these days.Furtheremore, many CD's are atrociously badly compressed and multiple generations away from the master recording. Unfortunately the format of a recording is no guarantee of fidelity.
You are absolutely correct! Resampling is another myth , no amount of resampling will add anything that wasn't there to begin with!No need to apologise, we're just having a chat. Do you believe that a hi-res file of the same recording will somehow cure this? I don't because you don't know which master has been used for the recording, as you say it could be generations away from the original... the original may not even exist now. Very difficult to know what you are actually purchasing these days.
Personally, it's my opinion that hi-res is just another way of parting us with our hard-earned cash.
However it is nice than it will not chop higher resolution material if there were something there again in my experience anything over 24/96 is just bragging numbers, the issue is if the release is at those higher frequencies you need a decoder that can handle them or they are unplayable.You are absolutely correct! Resampling is another myth , no amount of resampling will add anything that wasn't there to begin with!
Yes it has a usb port all you need is the correct cable/adapter. USBC is compatible with all previous standards.Hi people.
I want to use it as my desktop / monitoring speakers, without amplifier.
Would like to know how to simply connect to my Mac book pro using usb-c? No airplay but old cable.
is an adaptator enough?
Regards
Hi,Yes it has a usb port all you need is the correct cable/adapter. USBC is compatible with all previous standards.
Actually yes, I have a pair of new LS 50s Wireless, 3months old, bought them, got sold the idea of not getting wired with Cambridge amp etc and go for wireless versión, normally it takes 20 mins to connect to them, I've reset them, got latest version of app etc etc, the only way I can walk in room and listen to music without wanting to throw them out the window in blue tooth..... Can't belive the v2 has a new app and v 1 doesn't, speakers sound amazing, app is terrible. Would be very curious to see feedback on new app. For me, I would stay well away from wireless versión and recommend an very good amp and go wired... My opinion... From previous experience... Wish I waited for v2. Had no idea they were coming.Does anyone spending two grand on excellent Hi-Fi speakers really use Bluetooth much? It is a last resort in my book.
Sorry to hear about the problems with the V1 version. I have read in various publications about issues with the app. I'm crossing my fingers that the kinks have been worked out. Did you try to wire them to your network?Actually yes, I have a pair of new LS 50s Wireless, 3months old, bought them, got sold the idea of not getting wired with Cambridge amp etc and go for wireless versión, normally it takes 20 mins to connect to them, I've reset them, got latest version of app etc etc, the only way I can walk in room and listen to music without wanting to throw them out the window in blue tooth..... Can't belive the v2 has a new app and v 1 doesn't, speakers sound amazing, app is terrible. Would be very curious to see feedback on new app. For me, I would stay well away from wireless versión and recommend an very good amp and go wired... My opinion... From previous experience... Wish I waited for v2. Had no idea they were coming.
Unfortunately no, I'm sure that would work, however I would have to smash about 10-15m of wall over windows etc to get a cable there. Would have made them better I'm sure, problem is it simply does not connect. Maybe I'll buy a cable to try that but I'm not going to achieve anything as I'm not having a cable run through my living like that. Thanks for your response. KSorry to hear about the problems with the V1 version. I have read in various publications about issues with the app. I'm crossing my fingers that the kinks have been worked out. Did you try to wire them to your network?
I can imagine the frustration, and in a way you’re agreeing as you only used a Bluetooth in desperation. My point is it wouldn’t be first choice!Wish I waited for v2. Had no idea they were coming.
LS 50 wireless II - seriously, several competitors.
- Dynaudio Focal XD
- Buchardt A500
- Even Edifier S3000 (fraction of the price)
