Question KEF ls50 wireless 2 / Amazon hd
leemccann1
81
34
4,570
Hi all
just bought some ls50 Wireless 2 and very happy with the sound, they are amazing.
but I’m using the KEF connect app with Amazon hd and on some songs I notice a clicking sound at the start almost like the song is skipping. It’s only does it right at the start and then it’s fine.
it doesn’t do it on every song but it does do it when I play the same song every time.
ive got good internet speed and the speakers are wired into the router and I’m using the cable to connect both speakers together.
any ideas what it can be?
RoA
665
373
2,270
Great speakers, gratulations. Sorry, can't help with the clicking sound. Perhaps re-install the apps and see if it continues. Perhaps it's a compatibility issue with Amazon music. A quick Google should shed light on it.
