Kef 3005SE Vs B&W MT-25
MadDog*1
7
Hey!
Looking into buying home cinema speakers. Thinking of Kef 3005se or B&W MT-25... any ideas on which is the best road to go down? Thanks!!
Welcome.........
Can i ask what the rest of your system is?????
What is it used for? movies only?
But, to be honest, your probably going to be better at answering the OP's question, Clare....
Especially as I've not heard the B&W speakers......
I can't answer the question until I know more about what the speakers are for.
It'd be easy to just say 'B&Ws' as they are our Product of the Year in that category. Yes, they're damn fine all-rounders (hence the Award), but in some situations the five-star KEFs may suit a set-up better.
There's rarely a simple 'buy that' answer - and that's before the OP has auditioned
Yes, I meant after the OP had answered my questions.....
I think some people get a bit apprehensive about going for a demo....I know I used to.
I put it down to being 'worried' about pressure salesmen, or being obligated to buy something, which I have not found in the hifi/av shops I have demo'd in...
(Creative Audio, SMC, Hifix)
Find a good shop and go enjoy listening to the two different speaker systems, MadDog.....
Hi
I had the same shortlist last year, and managed to demo them at a local SSAV. I think you'll be impressed by either but I chose the Kefs for three main reasons;
- i found the dedicated Kef centre speaker gave more authority to dialogue
- the B&W sub didn't feel as integrated or make the same impact
- the Kefs were significantly cheaper; I appreciate that may have been a 'special offer' but i think the difference was almost a couple of hundred quid.
I know several people with the B&W, and they are all very happy with their choice, so I might suspect that the set up of the mt25 in the shop was not 100%.
However I am still perfectly happy with my choice. I use them a lot for music; using the marantz6004 and sonos. They might not be top range HiFi speakers but sound very enjoyable.
Go and demo; you can't make a 'bad choice' from those two but you might prefer the tone of one of them.
Hey, thanks!
I'm buying into the whole seperates game for the first time.
I was thinking of pairing either the Kefs or B&W speakers up with the Yamaha RX-V1067.
I currenyly have a 46 inch Sony Bravia KDL 40W4500 with Sony Bluray player BDP - S350.
Primarily i would be using the speakers for movies and on occasion music. I also enjoy gaming, XBox 360.
The vast amount of use will be for movies.
Cheers!
Though one this, because I do believe the KEF centre speaker handles the dialogue better than the M1, but I love the look of the M1's, I've owned both packages by the way.
The M1's with ASW610, rather than the 608 would probably be my choice, but I beileve the 610 is hard to get hold of.
I would suggest you have a listen to both and make your mind up which sounds best, good choice in AVR it's fantastic BTW, the new KEF T range might be worth looking into if your budget allows too.
Cheers Mark, I'll have to dig behind the couch in hope of finding an extra few quid, would love the T series!
I'm going to audition the T series along with the Apex tomorrow so I will let you know my thoughts too..
We've got a major First Test of the KEF T series speaker package in our next (March) issue - being posted out to subscribers 4th Feb; in shops by Feb 10th.
Clare Newsome:
Can you gives us any idea (without giving too much away) how these fair, my wife did not like my RX1/C setup, she does not like the R250HD I have currently and is not over keen on the Apex. The T series would be a solution she could live with, if I can!
I will have these or the Apex early next week hopefully.
I'm afraid I can't give you any clues!
Have a good listen and see what you think.
One point to consider - your Yamaha, while excellent, would be better paired to the KEF 3005SE/KEF T Series/B&W MT-25 price/spec level; the Apex package truly thrives on the end of even more power.
Thanks clare, it was worth a try, and I fully appreciate your comments on the 1067, however, I was trying to future proof myself with the Apex. this would also allow me to keep the RXFX at the rear, as I think if I went with the T series I would need to change the rears also (Do you agree?), it's just a shame they don't do the T series in White.
