JAMO A102HCS5 SPEAKERS
could anyone tell me which well regarded amps these speakers would be suitable to use with bearing in mind they can only handle 60 w continuous and 80 w for short periods ( jamo web site). these speakers are what i want but there dosent seem to be much choice of amp
thanks
The onkyo range seems to stealing all the awads and i'm sure the new 606 would be great with those mate.
it does seem good but it puts out 140w per channel, which would appear far too much for the jamo's
It will automatically adjust its power output to what the Jamos can handle. It has an auto set-up routine that it will do in order to get all the settings right for your listening environment and speakers. Once wired up, it's all fairly straightforward if you follow the instructions.
thanks, is this the case with other amps , or is it just the onkyo that does this
