Gerrardasnails
PJPro:pete321:
PJPro:Where do you live?
You're starting a rod for your own back there! Thanks, but I'm going to try and persevere with trying to get bit perfect with WMP/MCE. I'll be keeping an eye on the ReClock updates with my fingers crossed.
As I write, I'm listening bit perfect via FB2000 to a 24/96 WMA Lossless download from Linn of Highwire by Dawn Langstroth, sounds great.
Alternatively, you could try and follow my primer and I can give you a hand when you get stuck. It can be tweaked to provide this...
...which is what I think you are after.
TBH, I rarely use the chronoflow front end myself......it's just bling. I mainly use the one above.
PJ, any idea what the problem is when I install the ASIO plugin there is no issue. However, when I try to go into options in WMP to enable it, I get ASIOWmpPlg:SOFTWAREASIO registry access error; error code 2.
