The fast this they easiest because everybody likes easiest and the safest is to do cardio first thing in the morning when you wake up on it empty stomach doing cardio first thing in the morning for 30 minutes is the equivalent to doing it for an hour and a half later in the day and here's why first thing in the morning alright your body is as empty and fried calories as been best thing the entire time you've been asleep so when you wake up your empty your body is depleted in so when you start doing cardio that depleted your body is Original Garcinia Cambogia able to deploy right into your fat stores or utilize the fatty acids as the energy to keep you down like butthe only way that's going to happen is if you're working out and doing your cardio in your target zone and the way that you find that it's a simple calculation it down below you take 220 minus your age and you get number alright you're really need to know that that number is your one hundred percent heart rate reserve our right but this number you're going to then multiply it by two numbers you're going to multiply it by .6 endpoint 75 you're going to get two numbers that he got it upper and a lower range in this range if you exercise if you do cardio on an empty stomach.
http://bnathighgames.com/pure-garacinia-combogia/
