Overdose said:
The extra headroom inherent in more powerful amplifiers is to enable transient swings to be dealt with effectively. Like I said, use a 30W amp if it suits and you feel comfortable, but a more powerful amplifier is always a safer bet. If you want to draw analogies, it's not about outright speed, but acceleration and braking, both of which are done with less effort with larger engines in a vehicle.
The car engine analogy does not apply well to amps and speakers. Completely different moving a 1.5 tonne vehicle via combustion and mechanical means to moving a speaker cone weighing a few grammes via electro-magnetic means. Or if we're going to use a car analogy we need to come up with 2 cars where one of them is 50 times heavier and 50 times less aerodynamic than the other.
The important specification in an an amplifier in controlling a bass cone at levels below clipping is not the maximum power rating, but the damping factor which depends directly on the output impedance of the amp. It's possible that you could have a lower powered amp with a higher damping factor than a higher powered one. In this example the lower powered amp would have more control over the bass cone, leading subjectively to a tighter, less woolly bass.
And then you have how the amplifier reacts to impedance swings, inparticular impedance dips. Again, it's possible that a lower powered one could react better than a higher powered one.
Having said that, as a sweeping generalisation, valve amps with output transformers tend to have lower damping factors than high powered solid state amps and such valve amps tend to cope less well with low impedance speakers.
However in my system, with my highly efficient speakers where I have never come close to clipping with any of my amps, it's my 8 watt valve amp that sounds more dynamic than my 80 watt solid state one. I'm not sure why that is? Maybe it's because the valve amp is better at low level details, maybe because it overshoots, maybe because the class A zero feedback design results in a more dynamic sound than class AB with some feedback? Who knows?
With my speakers for my volume tastes, 8 watts is already plenty of power for me. Remember, my EV speakers are about 50 times more efficient at turning electrical energy into sound than your AVI speakers. So 8 watts into my speakers is the equivalent of 400 into yours. And 30 watts into mine would be the equivalent of 1500 watts into yours. Would you agree with me if I said that 1500 watts through your speakers would be overkill - quite literally?
