I will do the same for now. Please can you tell me how you set up the external stereo amp? The manual just say put two pre outs for the rear heights to a stereo amp. And that is it.bigboss said:I'll stick to my 9 channel amp + stereo amp for now, until there are more 11 channel amps which are reliable and affordable. Thanks for the feedback!
Audyssey will help you connect it. Check this thread:FunkyMonkey said:I will do the same for now. Please can you tell me how you set up the external stereo amp? The manual just say put two pre outs for the rear heights to a stereo amp. And that is it.bigboss said:I'll stick to my 9 channel amp + stereo amp for now, until there are more 11 channel amps which are reliable and affordable. Thanks for the feedback!
bigboss said:Audyssey will help you connect it. Check this thread:FunkyMonkey said:I will do the same for now. Please can you tell me how you set up the external stereo amp? The manual just say put two pre outs for the rear heights to a stereo amp. And that is it.bigboss said:I'll stick to my 9 channel amp + stereo amp for now, until there are more 11 channel amps which are reliable and affordable. Thanks for the feedback!
http://www.whathifi.com/forum/av-receivers/connecting-marantz-pm6005-to-...
