nads:bartlett23:nads:bartlett23:
the home hub is in another room entirely so i can't really hook the mac up to it directly. basically i've just moved into a victorian flat and i'm trying to work out how to do this without re-wiring the whole place! getting a BT engineer round might solve the wireless issue though and then i'd just need a DAC and aiport extreme by the sound of things...until then will any old router work to make the mac wireless?
cheers
will you be connecting to the internet with the mac?
does the router you have now have wireless ability?
i need to connect to the internet with the mac, yes. need to do this
wirelessly as can't connect to the BT home hub directly. just trying
to work out how this connection is made and whether it'll be the same
for connecting to the airport extreme.
you will need to get a nice long patch cable to set up the net work as you will need a wired connection for that. you then should be able to sort out a wireless connection with a dongle.
But i would get a Squeeze box touch and put your music on a USB hard drive and turn the Mac off.
plug the touch into some powered speakers and away you go. your music or the internet radio etc.
***, which part of the network will need to be wired up? (assuming i
don't go down the squeeze box route, which i may well do). getting confused now!
