Have a Panasonic SC-ALL70 sound-bar (and subwoofer) connected to a Samsung TV through HDMI ARC. When turned on today to play Amazon Prime via Apple TV, through the sound-bar, there was no sound so during troubleshooting I changed the input to Bluetooth, which successfully played sound.
I un and replugged the power cable but no success so I unplugged the HDMI cable, again without luck. I changed to a fresh HDMI cable and the display now flashed ”F70HDMI” on the display. Changing back to the first HDMI cable still flashes,the message. The only reference I can find to this is that it has lost its firmware and to try to reinstall it.
To reinstall firmware I need to select it through a setting via the SETUP button but this doesn’t change the flashing message, presumably because there is no firmware to operate with.
Is there any solution to my dilemma or is the sound-bar cactus?
