I'm not an audiophile, I'm just an older person who started out with nothing but vinyl and then like the idiot I am I threw them all away when I got my first CD player, somewhere around 300 records got round filed, some of those today would probably be worth some money.
Then vinyl started to make a comeback, so I dug out my old 1976 Rotel RP1000, placed the two stylus's I had on two different carts, bought some records along with cleaning stuff etc. But then I ran into a few problems, apparently most of the new pressings are not done well at all like they were done years ago when a recording first came out.
The other problem is you can go buy a vinyl recording that was originally recorded in 2025, but all you are getting is a digital mastered recording that was put through a digital mixer that was then put onto an analog vinyl record, but doing that didn't magically turn that recording into analog, it's a fake analog record.
The other problem I found out was that you can buy new pressings of a record done say in the late 60s, but that master tape has now degraded over the years, so the recording quality is not as good as it once was originally.
There are more and more modern recording artist that are beginning to do two masters' at the same time, one on digital and the other on analog but they are so far the exception, but hopefully as time goes on this will become commonplace. But I believe they still use a digital mixer for both.
You really have to do your research when buying a vinyl record or even a CD. If you ask Co-Pilot about the record you want to buy, you can ask it which is the best recording quality from that artist, and it will give you one or two choices and why those choices are the best. Not all CD's and records are recorded for release as top notch recordings, it depends on the price point, a recording found at Walmart will not be as good as one you might get at a record/CD store.
Vinyl is also delicate; you can't handle them the same as you would a CD or you can scratch them. Modern vinyl is not as durable as the older original records were, not sure why, might be due to virgin vinyl vs recycled? 180 gram records are supposedly virgin vinyl, and the those will have a better recording quality vs the thinner 120 or 140 grm records.
Modern vinyl is a hobbyist thing, something you want to do because you like the tactical feel of a record, you like the degree of warmth that the sound has, you like paying more attention to the care of the record.
If you are only wanting to try it, start with a low-cost turntable like the Audio-Technica AT-LP60X Fully Automatic Belt-Drive deck that cost around $220, don't choke on that price, my Rotel back in 1976 cost me $145 on a closeout sale, in today's dollars that's an $850 turntable! The reality is to get a good turntable in today's world a person should spend between $800 to $1,300, that is the sweet spot. Starting out don't go that high until you figure out if you want to go all in then save up money for something like a NAD C588 or a MoFi Studio deck. Once you get into the NAD or the MoFi, nothing more expensive is going to give you any hearing benefit, the long-term durability improves a bit with the MoFi. There are cheaper turntables than that Audio Technica, but the sound quality will suffer dramatically then you'll wonder what all the fuss was about with vinyl and blame the format and not the mechanical reasons.
By the way, LPs do not suck, they only suck to the person who didn't buy the right equipment, didn't know how to clean them and de-static them, etc., then they blame the format as I alluded to above.
