Is It Possible. Please Help
camcroft
1,020
666
20,070
Hi.I have been streaming my music using Bluetooth from my pc to a QED U-Play puck connected to my stereo and it works well.I recently bought the new version of the new U-Play which has its own outputs so that you have a choice of how to connect it to other equipment.I connected it in the same manner as I did with the old one and the sound was not as good so I changed back to the old one.The new one has got an optical output but my amp hasnt got an input for optical/digital.I was wondering if I could connect this to my cd players optical output.Is there anyway to make this work before I pack the new U-Play up to send back and of course lose money.Thanks for any help
No, you need something with an optical input. Some CDPs can function as a DAC as well but from your description it doesn't sound like yours can.
Just noticed your sig and have looked at the back panel of your CDP, you definitely cannot use it as a DAC.
You can pick up DACs for about £30, but any improvement is likely to be minimal and you would probably be 'throwing good money after bad'. Is the difference in the two versions really significant?
Hi.Ben.There is quite a difference in sound quality to be honest I couldnt believe it I thought that there would be a difference given that I could use better interconnects
You may as well just send the new one back and take the postage hit then. Without other system changes it offers you no greater functionality and seems to have made your sound worse.
Yes .We were in York the other week we dont have store near us we are in Lincolnshire and the nearest is about 70 miles away so posting it back is the only option
