Is it better to connect subwoofer to speakers or to the amplifier secondary output?
iiv
My old 80's amp has two different speaker outputs (but only two channels - the two outputs are identical). It doesn't have a sub output, so I will need to wire it up either using the unused speaker output or by adding more wires from the speakers' inputs. What would be better? Does it matter? Thanks!
iiv
I think I might've not explained it properly: the amp doesn't have a sub out. It does however have two speaker outs (for A/B testing, I presume). My question is whether I should connect the sub to the A out (which my speakers use) or the B out which is currently unused.
skinnypuppy71
375
240
2,270
I'd use the output that the speakers are using, the subwoofer will then receive the exact same signal that the speakers are also receiving, I'm assuming you're using a active subwoofer, if you are using a passive sub then this route might not be suitable,
Gray
You'd be effectively connecting to the same thing of course - so maybe go with whatever is convenient (closest to the sub).
The amp's unused speaker terminals probably involve additional switch contacts - so if you choose the amp end, do as skinnypuppy says and pair off from the currently used amp terminals.
twinkletoes
500
350
2,270
You have to be careful not all amps like being connected at the speaker terminals. High level. It’s generally better this way but again not always possible with some amps.
To be on the save side I’d connect to preout’s ” low level” doubt you notice any difference in sound quality in all honesty
That’s a assuming it’s an active subwoofer
If passive you’ll need make sure the amp has the power to drive it.
roaduck
208
41
320
My big Danley and BK Monolith + both support direct connection to an integrated amp`s speaker terminals - either bare wire or stacking banana plus to locking XLR neutrik on the back of the subs.
It depends if the sub has dual inputs - I`ve had my BK plugged into sub pre out of a micro system and 2 amp speaker terminals on my int amp simultaneously with no problems whatsoever.
Vincent Kars
316
299
2,270
No. Most of the time you can choose A, B or A+B. B is supposed to be a second zone.
As it is a 2 channel amp, you have 1 amp per channel hence 1 speaker per amp (A or B) or 2 wired in parallel (A+B) to a single amp.
Check your amp as the specs often are 4 Ohm speaker impedance when using A only and 8 Ohm speaker impedance if using A+B. Simply because 2x 8 Ohm speakers in parallel yields a impedance of 4 Ohm and 2 x 4 Ohm a load of 2. 2 comes close to a short so your amp might not like it at all.
Wiring the sub to A or wiring the sub to B and set the amp to A+B won't make a difference electrically. You simply have your speakers and sub wired parallel.
roaduck
208
41
320
Subwoofers can have the normal unbalanced low-level RCA phono inputs and balanced high-level XLR neutrik inputs as well but the balanced (earthed) sockets are usually reserved for prosumer, high-end, PA and studio sub-bass hardware.
You can also get round the problem of no pre-sub out terminals on an integrated amp with hardwired in-line male-female phono plug/sockets with built-in resistors and/or trimmer pots.
I have also used simple mini passive preamps with high level inputs with good results in the past.
There are 3 distinct types of units but the most common are line output converters.
The uni/bidirectional hardwired phonos with built-in resistive attenuation are not that expensive either - about £20-£50 upwards.
Something like this would suffice
Or one could utilise a passive pre-amp like this
Of course this solution is for an active sub.
If the OP only has a passive sub personally I would put the combined left and right output from the second set of speaker terminals into the LOC in parallel.
One can also utilise a subwoofer bass management preamp with mirrored and high-level inputs and DSP like an Antimode.I had the 8033 years ago and it was brilliant - it irons out the boomy peaks and boosts the troughs - all automatically.It is a lot simpler than the Behringer DCX2496 which is very versatile but requires a steep learning curve, patience and plenty of trial and error.I don`t need a sub management DSP unit these days.
I have one of these that one can use in conjunction with RCA to XLR leads.
Another solution is an analogue or digital parametric equaliser with high level in or a DSP subwoofer bass preamp from a semi-pro/pro manufacturer.
iiv
That's very useful knowledge, thank you.
As you have assumed, the subwoofer is active. Thanks for the advice everyone!
