iPod to amp or external DAC
Al ears
I have the ability to connect my iPod directly to a line-in on my amplifier using a Russ Andrews GQ24 cable.
I also have an external DAC.
Is there any benefit to be had in the way of sound quality in taking the connection thru the DAC rather than directly to amp?
well if you want to use a DAC you will need a suitable Dock to take the native digital signal from the iPod. so that will be a few more £, IIRC 150 ish.
Ok realise that is a possibility but 'scuse my ignorance but what exactly does the Russ Andrews cable take in the way of a signal from the iPod? It connects to exacly where a dock would. Does it not carry a digital signal from the iPod?
Perhaps it carries an analogue only signal from the iPod, I do not know.
If that is the case how exactly does something like the Onkyo ND-S1 dock get a digital signal from the same port on th iPod??
Alears:
No. The GQ-24 is simply an analogue connector (which is why you connect it to an analogue input on your amp) so all the conversion duties are carried out by the built-in iPod DAC.
The Onkyo ND-S1 allows the proprietary iPod digital signal to to be output to your DAC (whereas a simple Apple iPod -> USB connector would not work).
Alears:The Onkyo it is then - presumably this is best connected to the DAC with a good quality digital 'phono cable?
Or an optical cable.
Alears:Is there any benefit to be had by using an optical cable?
That's a whole other debate and can be cheaply proved to your own taste given how little an optical cable costs.
I use optical, coax and USB - from my digital sources to my DAC - because I have to. (I need all three).
Alears:
Gotcha Chebby
Doh!
no Phono cables. you are sending a digital signal so either an optical or Coax digital cable.
Phono cables from DAC to AMP yes.
