Ipod connector for car with docking station already fitted
Hello,
I'm trying to locate a cable to connect my iphone 3G to my inbuilt docking station in my VW Golf. Unfortunately my iphone is too big to fit into the docking station - my car pre-dates the iphone. I checked at my local VW garage who had no ideas on how to solve this issue (they did try unsuccessfully to ram the iphone into place...). I also contacted Apple who did not have any suggestions to get round this.
Does anyone know of a cable, effectively an extension cable, which I can plug into the docking station and then connect into my iphone?
Many thanks
richardw42
299
Can't post links as I'm on ipad settings. But if you go on ebay and search.
BLACK DOCK CONNECTOR EXTENSION CABLE
Is this what you're after ?
audioaffair
100
I had problems with this as I didn't want a fixed bracket and most of them are bulky/cheap. In the end, I found the best solution was 2 velcro pads (one stuck to back of iPod, one on flat part of the dashboard). Works a treat - but make sure to pick good (i.e very sticky) pads.
Andrew Everard
1,878
£2.95 plus £1.99 postage on Amazon
