There speaks a salesman!davidf said:Surely if you’re going to spend that much, you’d just go all out and buy an X?
Surely if you're going to spend that much, you'd just go all out and buy a Samsung?davidf said:Surely if you’re going to spend that much, you’d just go all out and buy an X?
chebby said:There speaks a salesman!davidf said:Surely if you’re going to spend that much, you’d just go all out and buy an X?
”if you’re going to spend six hundred you might as well round it up to a thousand”
Not really, I just find it crazy to spend so much on something (an excessive amount, some may say) to not consider something that might be better for a little more. I certainly wouldn’t buy a phone for £600, but if I was going to, I’d just go crazy and just do it properly, particularly if you’re going to get four times the memory, plus whatever other benefits the X brings.chebby said:There speaks a salesman!davidf said:Surely if you’re going to spend that much, you’d just go all out and buy an X?
