Integrated or Seperate Amplification for Dynaudio Emit 20
Maxprocrj
7
Hello...friends
Looking for some suggestion on amplification options for my new Emit 20.
Like extended top end and punchy bass.
Thanking you in advance.
Not really for the OP who already has a new pair of Emit 20, but for anyone else looking to build a system around these speakers.
The Lyd 7 uses very similar drive units in an enclosure of similar size, but is fully active. The crossover is performed in dsp which allows the crossover point to be moved clear of the critical midband, improving clarity and increasing power capability.
The dsp is also used to 'tune' the bass to gain a little extra extension and to modify the loading (damping) on the bass driver to allow for easier positioning with regard to room boundaries. Altogether a much more sophisticated implementation of the basic design than the passive models. Twin 50 watt amplifiers drive the bass and treble units direct, no passive crossovers in the way, so real world power capabilities are much higher than any regular 50 watt amplifier.
Altogether a more potent, bolder presentation than you might expect given their approx £1000 price tag, just add a dac/preamp or a streamer pre-amp to complete your system, prices start at just £1250 plus stands and cables.
radiorog said:
Check out the Roksan K3, great match for those speakers.
This and all the above suggested amps will be good fits imo. Also Naim 5si. But without audition, SH might be your best bet, since you can sell it further if you don't like it.
Why would you consider seperates? Only if you play records, i would say. Otherwise don't fill the pockets of those who want to sell you 2 seperate boxes.
