integrated amps with pre outs
audioaddict
114
A friend has asked me to find out if adding a power amp to an integrated with preouts means that the integrated can just be used as a pre amp with out the need for bi amping..........ive had pre power amps in the past but never used an integrated as a pre amp, so i couldnt give him an immediate answer..........i knew someone on here could help...........thanks guys
Blacksabbath25
I have pre outs on my amp if I wanted to by amp do you need the same amping power as my marantz pm8005 as I still got my pm6005 I no its not got the same power as the 8005 ? As marantz do not make a power amp unless I am thinking wrong on the power amp side of things. But interested in give it a go as I have never done by amping before
gasolin
They do make power amps
http://www.marantz.co.uk/uk/products/pages/productdetails.aspx?catid=hometheatre&subcatid=avamplifier&productid=mm7025
Blacksabbath25
. Ok thank you I see them but a bit confused why do they say AV power amps for are they meant for home cinema use only
Only just noticed this thread.
Yes, you can bi-amp pretty much any power amp to any integrated. When I had my Arcam I toyed with the notion of using P80 - Mrs. P wasn't keen as it was adding another box.
Wherever possible try and use the same make power amp that matches the integrated. Always good to have matching aesthetics and a common remote. Also when bi-amping you'll need to bi-wire the speakers to make the most of it.
chebby
1,257
34
19,220
Bi-amping not required apparently ...
"A friend has asked me to find out if adding a power amp to an integrated with preouts means that the integrated can just be used as a pre amp with out the need for bi amping ..."
