davedotco said:What seems a relatively simple request turns out not to be so simple in practice.
Putting Bluetooth imto an amp requires an onboard dac, which immediately shifts the emphasis onto digital playback, and since vinyl is the ultimate analogue source this functionality is rarely seen together.
You can find some receivers that will do all this, the Yamaha RN602 for example, but that does have a lot of extra functionality that you are paying for but perhaps do not want. Not so easy if you want a more 'purist' stereo amp.
I am sure such an amplifier does exist, but I can not think of an obvious example. Personally I would split things up with an outboard phono stage and a Bluetooth amplifier, it may give you some more options.
DannyB said:davedotco said:What seems a relatively simple request turns out not to be so simple in practice.
Thanks dave,
I was thinking maybe something like this http://www.cyrusaudio.com/products/one-series/cyrus-one
I seem to have created a little typo error in the heading I'm looking for an integrated amp with PHONO PREAMP and BLUETOOTH not PHONO, PRE and bluetooth if that makes sense!
Damned the misplaced comma.
DannyB said:I seem to have created a little typo error in the heading I'm looking for an integrated amp with PHONO PREAMP and BLUETOOTH not PHONO, PRE and bluetooth if that makes sense!
jjbomber said:DannyB said:I seem to have created a little typo error in the heading I'm looking for an integrated amp with PHONO PREAMP and BLUETOOTH not PHONO, PRE and bluetooth if that makes sense!
Rotel RA-11 and RA-12 have phono stages and bluetooth. Is that what you mean?
