kevinJ said:mystickangaroo said:Thus far, I've shied away from Cambridge simply because their systems under $1K seem to do consistently well but never really outstanding in the hifi reviews I've read.
Why would that hold you back? It's not because a component only gets 4 stars, that it can not shine when combined with other electronics is a system.
WH says my RX8 bass is somewhat overblown (and using a NAD amp, it is), but when you partner that with a cdplayer and amp that are a bit lighter on the bass side, magical things start to happen. (hence my setup)
It's all about synergy, and yes it might take some time before you find the right setup, but it's always worth it.
So don't rule out electronics or speakers just because they didn't receive those 5 stars.
Point noted. I didn't intend to imply that Cambridge hasn't made the shortlist, because it has. I'll definitely be auditioning them. The problem with the Cambridge Audio Azure 650 for me is that it doesn't include a phono input which will require me purchasing a separate phono stage, correct?
RS, damn you're very convincing with that Onkyo. To be honest it has a million features that I'd probably never get around to learning how to use but you say it's phono stage is solid and the ability to really accomodate digital audio (and flac!!!)is pretty impressive as well. And the price is insanely alluring, so much so that I could actually start contemplating my Rega Planar turntable way ahead of schedule. Seriously, it's currently selling for less than $300 (US)!!!
I still want to hear what that Brio sounds like. Just seems appropriate considering i'm shopping (eventually) for a rega turntable. How do you think it handles digital sources (i.e. laptop, iPod). Would the separate DAC be absoutely necessary or just an additional luxury?
