Howdy guys,
Long time reader first time poster here. Just want to sort out my puzzle here. Had auditioned Monitor Audio silver 6 speakers in couple places. Really liked the way they sound, look and build quality. Now got a bit confused with the amp I should go with these speakers. I mostly listen to various old school rock, some heavy metal and occasional jazz/blues is also on the list. As the source I would be looking to stream files from my PC/iPad/iPhone, but that could be sorted out in the future through various DAC options. For now I want to play vinyl and have pretty much decided on Rega RP3. So to me the amp is the only one outstanding piece of the puzzle. I would like to narrow down amp options to maybe 2 or 3 and maybe convince shop owners to let me audition them at home. Not sure if that's possible though. Recommended specs for MA Silver 6s are 60-150W, impedance 8ohms so not too sure how well would it go with the options bellow. The budget is around $1000 for the amp, so what I would be looking at is:
NAD - C356BEEE with aditional phono input or dac board (if I go with phono input board, then I would buy separate DAC later on).
NAD - C326BEE with separate phono stage unit and separate DAC
Rotel RA-12 - got phono input and DAC
Cambridge Audio 651A - no phono input, got DAC (therefore additional phono stage required)
Cambrige Audio CXA60 - no photo input, got DAC (therefore additional phono stage required)
Arcam FMJ A19 - got phono input (would consider DAC in the future), but only 40w per channel, might not be enough to drive Silver 6
Marantz PM6005 - got phono input and DAC
Rega Brio R - got phono input (additional DAC would be required)
So, has anyone have any input or any other opinions or options? Maybe heard of the similar setups before? Would highly appreciate advices of whatever you think.
Cheers guys,
Storie
Cheers guys,
Storie
