In built Airplay question
Fuzzy Bear
29
Is it possible to give names on built in Airplay devices?
Very trivial but I just prefer to name things such as, Living room, kitchen, etc
Makes it easier for friends/family use devices.
Good question. All my devices are connected using AirPort Express, so I can name each zone individually in Airport Utility. Not sure if you can do the same when AirPort is built into the device, sometimes (like Apple TV) it has its own name.
Yeah, that's what I meant. The Airport Utility tool. Not a biggie in the scehem of things. But i'm curious.
And of course freinds think it's hilarious to name zones by rude names.
On the B&W Zeppelin Air set-up app you can name each unit individually, if you had several around the house, but this won't necessarily apply to every AirPlay product as each has a different set-up procedure. Gear4 AirPlay docks can also be renamed.
