Feb 8, 2025
Hi all, first post so here we go.
Having trouble with my dac inasmuch I’ve plugged it in to usb>rca>speakers with a Wiim mini streaming but I’m getting no output.
Drivers are current and sound settings are set to Ifi Zen but gettting nothing out at all.
Any ideas please?
Al ears
I have brand new Argon Fenris A5’s that work perfectly when I stream from the Wiim Mini.
You will note other posts on this forum that talk about iFi issues when using USB.
Presumably the mini is attached to the dac with an optical cable?
What position is the switch on the back of the Zen set to?
No the zen is plugged into USB and then RCA to the speakers, the Wiim is plugged into another USB on the PC.
camcroft
942
575
19,770
Where is the USB plugged into.I use mine into the iMac this way the mac powers the Zen Dac and also covers the sound connections otherwise it's using RCA and power from the wall socket. Thats why they supply both USB and RCA cables and a power lead. I presume that we are talking about the iFi Zen Dac V2 because iFi "Zen" covers a big range including a phono stage.
