- Aug 10, 2019
- 2,556
- 5
- 0
Hi all..
Got a Denon AVRF100 surround system which came with the NXT speakers. One has blown so need to replace. I thought I was stuffed because (in this setup) everything goes through the sub via a umbilical type cord. But found the manual and it seems I can connect any sub and speakers.
Going to use it purely for stereo and not surround sound until I can afford a new system. The speaker connections on the back are the spring loaded clamp type (I assume this is not ideal?)
Currently to make it sound ok playing cds I have to use the subwoofer, will this still be the case if I get some decent speakers?
This means nothing to me but the manual says speakers with an impedance of 6 to 16 ohms can be used.
Room is about 4 x 4m. Dont want great big floor standers so any suggestions which I am best to go for
Any other info you need to help give me a shout and I will see what I can dig up
