steve_1979 said:TrevC said:CnoEvil said:It depends on the impedance curve of the speakers ie. do they drop to under 4 Ohms.
...though TBF, I suspect you'll be fine.
Is there an impedance curve for every speaker WHF tests? If not, how would you know if your ***** rated speaker is a difficult load? In the absence of a frequency response graph, how can you tell if the speakers are going to sound a bit bright?
+1
I've said that to them several times over the past few years but they never reply.
There's no rule says you can't look at other mags, e.g. HFN+RR or Stereophile, which do publish impedance and FR graphs.
