Deleted member 2457
Yep, I can see the swirls. Yep, I thought that too that I might end up having more issues when this is a bit of a non-issue at the moment for me. I will just see what LG come back with but even then I will probably just keep it. If it wasn't on Sky Sports 1 on the football then I wouldn't be that bothered, but just viewing it now I couldn't even see it. One thing I don't want to happen is that it gets worse or something like that.ellisdj said:I havent had time to check anything else Gel, this is CBeebiesHD on Virgin - I noticed this this morning for the first time. Never bothered looking before.
If you look hard enough you will find at least one fault with everty tv - normally more than 1 - none of them are perfect. There are other far worse like DSE etc
I dont think yours is a fault - if that is all you have noticed in 8 months of ownership and use then I think your doing ok - you might swop the set out and have more obvious problems and flaws with the new one.
If it was doing it in every channel on sky I would say maybe but if its only certain channels its the channels - faults are consistent or sometimes intermittent - but if it was intermittent you would get it randomly with all content, not just the same channels all the time
